08-27-2017 07:33 PM
I have a Canon MF620C all-in-one and I removed the paper tray to add more paper and now the paper tray won't go in all the way. It stops with about 2.25" of tray still extended.
I've tried everything to get the tray back in. Anyone else have the same issue and get it resolved?
08-28-2017 07:26 AM
Hello FuefinaWG,
It sounds like you may have extended the paper tray so that it will accommodate legal sized paper. See example under step 2 at this LINK. What size paper are you using in your Color imageCLASS MF620C series printer? Are you certain the paper tray isn't extended for legal sized paper?
If you need immediate assistance and you're in the USA, please click http://Canon.us/ContactCF for our US-based support. If you're outside of the US, please click http://Canon.us/4xf7 for support options.
01-12-2018 06:49 PM
My upper tray will only go in about an inch and is blocked. I loaded 5x7 photo paper but beilieve the printer thinks that the cassette is in place, and not outside the printer.... MG7520
Thanks
07-28-2018 12:49 PM - edited 07-28-2018 02:54 PM
Did you ever get an answer that worked?
I am having the same issue, and it is not set for legal size paper
Canon MF628Cw
And I'm in the middle of printing something and I need to get this project done quickly.
HELP!!!
YIPPEE!! And KUDOS to SONYA at Tech Support.
There's a little lever that causes the tray to extend or contract that I wasn't aware of.
05-09-2019 05:23 PM
I have same issue on Canon MB5000 series printer. Cannot get tray to go back into printer. Printer & tray set on letter size paper. Cannot even get it started into the printer. Have tried every possible angle, etc. Please help!!!
09-19-2019 03:18 PM
09-19-2019 03:22 PM
Hello!
So that the Community can help you better, we will need to know exactly what model printer you're using.
If you're in the United States, and this is an urgent support need, please click HERE to enter your product information and discover your support options.
If you're outside of the USA, please click HERE to find support options in your country.
Thanks and have a great day!
09-19-2019 03:29 PM
using a canon printer imageclass MF634Cdw
it is not because i'm using legal paper because i am not
it is not because of the little blue buttons
it is like something is keeping the tray from sliding into the machine in the back
09-23-2019 01:11 PM
Hi dfoitek.
If you have confirmed that the printer is sitting on a level surface, and there is nothing obstructing the back the of the machine, then we will have to recommend that you call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays). A representative will be able to further assist you.
01-21-2020 10:42 PM
I have a cannon MF733Cdw printer.. Paper tray won't reload into PRINTER! It's frustrating....wasted a lot of my time on this!
I need a quick solution!!! Thank you.
