Need simple solution to reconnect Scangear to Imagerunners in different Offices that laptop goes to.
Shutech
So I have several laptops that move between offices. Offices have Imagerunner Adv 5355II. Scanning is used heavily from the Imagerunners to the laptops.
It is bulky to open up scangear and then remember the IP address for the Imagerunner in that office and then change to that machine.
I am currious if I can use run command and run scangear with attributes or creat a script so that I have Icons for each office and when the user clicks it, they are automatically connecting scangear to the Imagerunner in that office.
Short is wanting a one click sollution for floating laptops to easily connect to Imagerunners in differnt offices so as to be able to scan.
Thank You
1 REPLY 1
Moderator
Moderator
Hi, Shutech!
Thanks for posting! While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
