NEED HELP ON MF4770n after update driver cannot use scanner.
Immortaltale
I'm using windows 7 64 bit system and use USB cable to connect printer to computer. After I did a printer driver update my scanner stops work. When I use tool box to scan document It shows this.issue.JPG
Thanks for you reply, I solved my problem by upgrade my system to windows10, thanks!
4 REPLIES 4
Use System Restore or roll back the driver to the version that worked previously.
Tried everything, I unstalled driver and switch to the old driver and have the same issues.
Hi Immortaltale.
Please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays). A telephone representative will be able to assist you with getting this issue resolved quickly.
