imageCLASS MF665Cdw printer makes one PDF for each page scanned
DRB_1
As stated above, my Canon ImageClass MF665cdw printer will not create a single PDF document from a multi-page scan. Instead, if I scan 20 pages through the ADF, I get 20 PDF documents saved. What do I need to do to make it create one PDF file from a multi-page scan? Is there special Scanning software that I need to use and/or a special way to configure what I have? I'm currently using the Canon MF Scan Utility V2 software.
Greetings ,
The setting you need to change is in the MF scan utility 😉.
Here is an example. Look under the save settings.  See a Data Format field.
2 REPLIES 2
Greetings ,
Thanks, ~Rick. That worked
