04-22-2026 03:01 PM
I have a Canon Maxify GX7021. When I print color, there are white horizontal bands across the page in the color portions. I've done a print head alignment as well as normal and deep nozzle cleaning. This happens with photos, word documents and anyfile type that displays color. How do I fix it?
04-22-2026 06:28 PM - edited 04-22-2026 06:29 PM
I suggest performing a nozzle check printout, it could help narrow down the source of the banding. Sometimes more than one deep cleaning is necessary, but lets see what the nozzle check shows.
Select Nozzle Check Option
Print the Nozzle Check Pattern
After printing, examine the nozzle check pattern for any issues:
| Pattern Condition | Action Required |
| No missing lines or horizontal streaks | No action needed |
| Missing lines or horizontal streaks | Clean the print head |
04-22-2026 03:02 PM
I am using Window 11 and connected to the printer via wired ethernet.
04-23-2026 08:24 AM
Thanks DerrickL:
Previously I had done a few nozzle cleaning cycles, as well as a deep clean. After your reply I did one nozzle cleaning followed by five deep cleaning cycles. That seemed to do the trick. No horizontal banding. Thanks for your help. Looks like multiple deep cleaning cycles was the answer.
