12-05-2021 05:51 AM
All the time, it gives me many print outs unless I stop it manually. In addition, it does not print out properly. Right end is always missing. I really want to have helps for these issues.
12-05-2021 11:29 AM
I know it looks like a "b" on the box, but the model of your printer is actually MF642Cdw .
Support | Color Laser | Color imageCLASS MF642Cdw | Canon USA
What OS are you using with the printer?
What application(s) are you printing from?
What driver did you install?
12-05-2021 11:41 AM
I use macOS Monterey (version 12.0.1). I tried to print out word document. I do not know about driver. I do not see in application section. In the preference of printer it says below. I wonder if it is driver or not.
12-05-2021 09:05 PM - edited 12-05-2021 10:31 PM
Please use the link I provided above. Select MAC OS 12
Download the driver for for your printer.
Remove the device from Printer and Scanners
Restart your MAC
Run the installer and follow the prompts to install the printer and its supporting software.
12-06-2021 05:58 AM
I installed the new version of driver and restarted. But still the same i.e. printer cannot recognized that printing was already done and right end is still missing because printing out to the right edge regardless the document is set to have margin of 0.5 inch to the right edge.
12-06-2021 10:02 AM - edited 12-06-2021 10:03 AM
My instructions were:
Download the driver
Remove the previous instance of the installed device
Restart
Reinstall the device.
Your post states you installed the new driver and restarted...???
12-13-2021 05:43 AM
I could not find the previous driver in the "application list". I downloaded a new driver as you suggested, then restarted a computer. Both multiple copy (after printing, "print queue" is still looking for a printer and continues printing) problem and missing the right end of document (regardless document margin setting) are persisting. Your help is greatly appreciated.
