MF743Cdw Scan-to-Email Function
jjveal
I've read other entries about configuring from a Gmail to get your all-in-one Canon MF743Cdw to send an email with a scanned attachment, following the instructions to the letter.  I just purchased this item and could not get it to work.  We created a separate gmail account without two-factor authentication, created an app password, changed the ports, etc.  None of it worked.  Totally at a loss on how to use this critical business function.  Any advice would be appreciated.  Here are my settings under the E-mail/I-Fax settings:
SMTP Server:  smtp.gmail.com
Email address:  xxxx@ gmail.com
Pop Rx: Off
Pop Authentication Before Sending:  Off
SMTP Authentication:  On
User name:  xxxx@ gmail.com
Password:  set using the App password function on Gmail
Use TLS for SMTP:  On
Verify Certificate:  On
Add CN to Verification items:  On
Use TLS for POP:  Off
I've tried this configuration using SMTP ports 465 and 587
1 REPLY 1
BobEbaugh
I had to go into the Google account settings and turn "less secure access" on.  See attached.
Good guide here too:
https://canoncanada.custhelp.com/app/answers/answer_view/a_id/1036411/~/configuring-e-mail-settings-...
