03-07-2020 09:59 AM
Hello,
Is it possible to scan double sided originals from the device control panel?
I cannot find any option to do so.
I can do it from the utility on the PC, but this is not convenient.
03-26-2024 04:34 PM
I had the same issue, and after working with a terrific Canon tech, we found the problem (at least in my case).
We tried removing all Canon drivers and devices and re-installing, but it didn't help. It turned out I had some sort of TWAIN conflict (it's a scanner standard for remote scanning). What DID help:
After that, I went into the MF_Scan utility and the checkbox was there. What I wanted was the Color and B/W options to be single-sided, and the Custom 1 and Custom 2 to be the same thing, but double-sided. It worked fine.
One other thing I liked: I turned off the date folder and aimed all scans to a single scan folder. I also changed everything to PDF to make it easier to file.
Hope this helps!
