03-07-2020 09:59 AM
Hello,
Is it possible to scan double sided originals from the device control panel?
I cannot find any option to do so.
I can do it from the utility on the PC, but this is not convenient.
03-09-2020 04:10 PM
Hi frunobulax.
Information about copying with the imageCLASS MF743Cdw may be found at the following page in the printer's Online Manual:
https://oip.manual.canon/USRMA-3547-zz-SSM-740-enUS/contents/devu-copy-basicope.html#0303_h1_01
03-09-2020 04:27 PM
I was asking about scanning, not copying.
03-11-2020 01:28 PM
Hi frunobulax.
I apologize for misunderstanding.
For scanning, each of the scan options will maintain their respective settings individually. A roadmap to each may be found at the following page in the manual:
https://oip.manual.canon/USRMA-3547-zz-SSM-740-enUS/contents/devu-set_menu_list_1-func-send.html
03-14-2020 11:18 PM
No, this does not help. Thanks for trying though. I wanted to make the choice at the printer on a job by job basis. Sometimes I need 2 sideded, somtimes I do not. I should not have to reconfigure the scanner every time I need to do this.
There is aparently no way to directly control this from the printer on a job by job basis.
The correct answer is you must use the MF scan utilty to change the setting. If you want to scan both one sided and 2 sided documents, you must use a custom setting.
To do this, open the utilitity, click settings, click the middle tab, you can now customize the 4 choices you have when scanning from the printer (Color Scan, B&W Scan, Custom 1, Custom 2).
You can customise one of the choices to do 2 sided scanning by checking "Scan both sides when scanning from the feeder".
Unfortunately, you cannot rename the Custom settings toi something memorable like "2 Sided color". You will have to remember which oif the 4 chouices you changed to do 2 sided scanning.
It is really frustrating is that there seems to be no way to configure this from the web UI.
10-29-2020 08:45 PM
This no longer works. "Scan both sides when scanning from the feeder" option is not avaialble.
I had recently updated the drivers, and now two sided scanning cannot be enabled.
06-02-2022 08:24 AM
I just purchased this printer and I can report that downloading the latest MF Scan Utility allows me to set the setting "Scan both sides when scanning from the feeder"
07-24-2022 12:58 AM
I just got this printer today, and I came searching for this answer as well. I thought that it wasn't possible to select "Double Sided" from the device control panel, because under "Send Settings" I only saw the options:
However, if you drag the choices on the screen up, you will find that there are more options you can select:
Really, they should have included some kind of indication (like a scroll bar) to the right to show that there are more options below. But in any case, the options are there.
10-11-2022 01:37 PM
I don't see "Send Settings" anywhere, may I please have more guidance?
09-06-2023 07:05 PM
I can confirm that on Mac, I have not yet found a "2-sided" scan option on either the Device itself nor in the Canon MF Scan Utility. How hard is it for a multibillion company to consistently implement an interface?
