07-09-2019 02:40 PM
I recently purchased a imageClass 743Cdw and noticed that the fan runs continiously even in sleep mode. similiar to MF733Cdw Fan Running Continuously post. Unfortunately that post ends with no useful information and an EcoStar device should not be really running a fan continously when in sleep mode. How do I get the fan to stop short of turning off the power?
11-15-2019 05:04 PM
Are you sure you did a full factory reset? Try one more time. Also post your firmware version.
11-15-2019 05:23 PM
11-15-2019 05:24 PM
09-11-2021 03:07 PM
I believe there's definitely a firmware bug here - and it would be great if Canon would investigate/ fix it. It's related to using the fax function. Out of the box, the fan works normally - and stops spinning when the machine goes to sleep. Once the fax function is used, the fan never sleeps. I've reset all the settings and the continuous fan goes away. However, using the fax function again causes the fan to spin forever again and the only way I've been able to stop it is by factory resetting the entire machine again. Obviously, completely factory resetting the machine after every sent fax is not an acceptable workaround. Soon after I got the machine, I called customer service and explained the issue. I don't think they understood and/ or never escalated the problem.
CANON - PLEASE FIX THE FIRMWARE!!!
11-24-2021 03:31 PM
Hello,
Receiving faxes should not make the fan run all the time. In this situaion, it would look like there is a problem with the hardware. I would suggest contacting our support team at 1-800-652-2666. Our agents would be happy to provide service options for the printer.
12-02-2021 10:00 PM
Hector - Thanks for the reply. I've had this problem since purchasing the machine several years ago. I actually did call your support team shortly after purchase (I noticed the problem right away) and they were not particularly helpful. I'm pretty confident it's a firmware problem and not a hardware problem - particularly because after factory resetting the machine it works fine, and continues to work fine until using the fax function. I would ask that you have someone at Canon try it out: set up the machine, plug it in to a phone line, send a fax. After that, the fan will not stop spinning, even in sleep mode.
