MF741Cdw How to Save Color Scan as PDF
JbamzMiguel
I need help in configuring the MF741 Cdw.
The issue is that, the Color scan is saved as Image while the B&W scan is saved as PDF.
How can I save my color scanned documents as PDF?
Thanks
3 REPLIES 3
Tiffany
Moderator
Moderator
Welcome to the Canon forum!
So that the Community can help you better, we will need to know
 which operating system is running on your computer (i.e. Windows or macOS and which version) Any other details you'd like to give will only help the Community better understand your issue. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
It is Windows 11..
Thanks
Hello,
You can use the IJ scan utility on the computer to change the file type of your color scans. You can open the Ij scan utility and change the setting using the steps in the link HERE.
Friends and Family
