11-26-2019 09:52 PM
System description: MF644Cdw connected to a Mac Mini running Sierra 10.12.6
Anyone know of a way to change the the destination folder for scans run from the scanner touch screen (scan to computer)? I know you can change the destination folder using the Canon MF Scanner Utility on the computer but this does not change the destination folder when scanning from the touch screen. I've also tried to change it using the Remote UI website without luck. Any help is appreciated.
11-27-2019 01:42 PM - edited 11-27-2019 01:44 PM
Hi dws2006
The destination when scanning from the MF644Cdw's operation panel is controlled in the MF Scan Utility. Open the MF Scan Utility, then select the second tab at the top of the settings window (illustrated below).
The settings for each option will need to be changed and set individually. Once you've changed a folder for one of the options, click OK, and then repeat as necessary for any additional scan types for which you wish to change the settings.
If you need immediate assistance with this issue, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
Hi dws2006
11-27-2019 06:24 PM
Thank you Darius, that's exactly what I was looking for. Feel kinda dumb I didn't find it myself.
07-07-2022 03:07 PM
This doesn't change the default on the printer. Scanning from the device still sends it to Users folder. How do you change it from web portal, aside from registering a shared folder?
07-07-2022 07:44 PM
I was using the first (computer) icon instead of the middle one.
But it would be nice to be able to configure in web portal -- is there a way?
