03-10-2020 07:57 PM
I've only had this printer for a couple of weeks.
I've been trying to print something that is primarily blue and it keeps printing a darker blue than it actually is. I've tried a few different progarms (PS, GiMP, Windows Photo Viewer, etc.) and two different computers. It all prints the same. I've tried playing with the toner by dropping the cyan down to about -3. It lightened it slightly, but now it looks dull. I've played with color management and either it gets washed out or washed out with a grey background (supposed to be white).
Photos print fine.
03-11-2020 10:38 AM - edited 03-11-2020 10:38 AM
If photos are printing fine, then the problem is likely with the ICC or color profile and the media you are printintg on. If these are not matched, color variation can result.
Other possible issues. Color calibration. If your monitor is not correctly set or calibrated, the printer my not actually be printing what you think you see.
So its very important for your monitor to be correctly calibrated, and for you to use the correct profile, color management and media to avoid unexpected or undesired results.
03-16-2020 12:06 AM
Thank you for your reply.
After calibrating, futzing with ICCs, and wasting a ton of paper and toner (I'm down to half on the starters), I ended up dropping the toner density down and raising the printer's gamma to 2.2; getting as close as as I can get. All of my programs print good now, except Photoshop. It has the same settings as all of the others, and no matter what profiles I used, it's still a bit darker than everything else.
