03-06-2020 01:35 PM
Just purchased the mf743cdw and went through setup. Must have done it wrong as fax answers everytime. Just the one line. I had previous set up to only answer/respond to fax tone after phone and answering machine. How do I go back to reset fax settings? Hey, I'm a senior and slow at it.
03-07-2020 10:41 AM - edited 03-07-2020 10:42 AM
Start here. This should help get your fax working again:
https://oip.manual.canon/USRMA-3547-zz-SSM-740-enUS/contents/devu-fax-rece.html#0412_h1_01
03-14-2020 10:32 AM
I changed the setting from auto to manual and it seems ok.
03-14-2020 01:43 PM
How do you set the Canon MF743Cdw back to the initial setup? I would like to reset all.
03-15-2020 08:48 AM
I believe that process is called "Initialize".
