MF634cdw beeping
barnkat59
I have an MF634 that keeps sending a message about the IP changing. It works and my PC connects, so that's not a problem. However, the beeping every hour or two when the message appears is driving us bats. How do we acknowledge so that the machine will stop sending the message?
1 REPLY 1
Hector
Hello Barnkat59,
The MF634 gets the IP address from the router that controls your network. If the router keeps changing the printer's IP address, you can set the IP address manually and the printer's address will stay at the address you set and will not change. You can set a Manual IP address using the steps in the link HERE.
