08-06-2016 10:47 AM - edited 08-06-2016 11:42 AM
Hello Canonfolks,
I'm having a problem with my MF4770n. The scan function suddenly won't work, either when I try to scan from the MF Toolbox, from the MF Scan Utility, or via the "Scan" button on the device itself.
It alwasy resturns "Error code: 2100010"
The only change on my has been upgrading to El Capitan, so my speculation is the problem could be related to that.
I've updated the Canon drivers to the latest, but no luck. I've "deleted" and "added" the printer in the printer system preferences. And the device is plugged in via USB, so there are no wireless issues.
Any suggestions would be greatly appreciated.
Thanks!
UPDATE: Tried plugging the device into a different computer. No change.
08-09-2016 12:37 AM
Hi trueheart0.
I will be able to assist you.
Please note that the MF4770n supports scanning with the MF Toolbox. It does not support scanning with the MF Scan Utility.
May I have you verify that the machine is set for network scanning by following the instructions below:
Once you have performed this step, please quit the MF Toolbox, and then try scanning by following the instructions below:
Should the error persist, please call us at 1-800-OK-CANON (1-800-652-2666).
08-19-2016 05:50 PM
