10-06-2021 03:15 PM
10-22-2021 02:53 PM
Hello Clogva1,
When scanning using the MF Scan utility, you can go into the save settings and you can select the option to check the scan results. When that is selected, you can choose the file name and the save location once the scan is complete. You can view the manual for the MF Scan utility using the link HERE.
We would be happy to assist with further the issue. To provide some feedback or some troubleshooting steps, please reply to this message with the operating sysem that is on the computer. Once we have that info, we can assist further.
10-22-2021 03:33 PM - edited 10-22-2021 03:38 PM
I did the preview thing and still, my file name has extra things added to it. I named the file: 0-DRN-385398-1.pdf, but the name it was given is 0-DRN-385398-1_20211022_0001.pdf. Imagine scanning in all the documents needed for a 40-year land record search and having to rename all those Deeds, Deeds of Trusts, Easements, and Plats. I told the program what to name the file. There is no option to uncheck adding the date and a four-digit number to the end. A program should not add to a file name without the option to turn it off.
A quote from the manual you linked to:
