08-13-2021 04:33 PM
When I try to print I am getting the following message in the Jobs window
Stopped - 'Filter' failed.
If someone could explain this & how to fix.
thanks :![]()
Gord H
08-14-2021 08:40 AM
Hi, musicmann!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or Mac OS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
08-14-2021 02:08 PM
macOS Big Sur Version 11.4
I encountered this issue when I tried to print a pdf using the Preview app.
08-17-2021 12:35 PM
Does anyone have an idea of how to fix this problem ?
10-22-2021 03:56 PM
Hello Musicmann,
The filter failed error message is a Mac error that point to a problem with processing the PDF file. In this situation, you can download and install the UFR printer driver for 10.11 using the link HERE. Once the driver has been installed, Click on the apple in the upper left hand corner of the screen and then click on system preferences. Once in system preferences click on Printers and Scanners.
In printers and scanners, you can use the - at the bottom of the window to remove any old connections for the printer. Once the connection has been removed, you can click the + to add the printer back to your printer list. When adding the printer, make sure the name of the printer appears in the USE box near the add button.
