MF445dw - Double Side Scanning Through Feeder?
mensan70
So, I need to scan a bunch of double sided docs on my mf4445dw.  Is there a way/setting for this on the canon scan utility?  Can't seem to find one.  If I manually scan via the glass it will ask if I want to add pages.  But via the feeder, it doesn't ask.
11 REPLIES 11
I need the version with "Scan both sides when scanning from the feeder" option.
Greetings ,
I'm running the latest version v1.21.0.2 on two lasers, and on windows 10 / windows 11 and both have the checkbox option for single pass duplex scan.  The older utility should not be needed.
Canon Support for imageCLASS MF445dw | Canon U.S.A., Inc. https://share.google/N4dY4pY06dDBP3x1A
Try opening the scan gear utility and select advanced, then change the feeder option to two-sided.  Close and reopen the MF scan utility and look for the option.
Friends and Family
