08-18-2022 12:06 PM
Has anyone ever experienced where this printer will scan (using the Canon utility,) via network, but not USB?
We need to use USB for these printers, so any insights/solutions to make it work via USB instead of network?
08-18-2022 12:27 PM
Sorry, I forgot to add: The scan utility works on the flatbed on USB, just the ADF doesn't work. So, a very specific issue.
09-13-2022 03:28 PM
Hello,
We would be happy to assist with the issue. To provide some feedback or some troubleshooting steps, we would need some additional information. If you could reply to this message with the information below, we can provide some assistance. For a more immediate resolution, you can contact support at 1-800-652-2666.
09-19-2022 12:18 PM
Thanks Hector. Sorry for the delay. Here is the info:
09-23-2022 01:05 PM
Hello,
The issue that you are describing usually points to the WIA service not running properly on the computer or something is blocking it from running.
In this situation, I would suggest pressing the Windows key and the letter R key at the same time on your keyboard. In the run box that appears, you can type in services.msc and clicking OK. In the list of services, you can highlight the Windows Image Acquisition service and then click the option at the top to restart. You can also try turning off any security software and then restarting the service if just restarting the service does not resole the problem.
If you continue to have issues, I would suggest contacting support at 1-800-652-2666. Our agents would be happy to assist with the issue.
