01-25-2019 11:00 AM
Hi all,
I have a Canon MF 733 Color Laser printer and for some reason the black print quality is not as dark as it once was.
This just started to happen. When it was new it was perfect. The printer is just over a year old and not used everyday. When I do print something it is maybe 5 to 10 pages.
Any clues as to what is going on? I went into the printing preferences and under the quality tab I chose "General" as the default.
Thanks much,
RIch
02-04-2019 12:53 PM
Hi rbaroncpd.
Please try to manually adjust the setting by following the instructions at the link below:
It is also recommended that you follow the steps below to adjust the density of the toner cartridges:
<Menu>
<Function Settings>
<Printer>
<Printer Settings>
<Print Quality>
<Density>
Adjust the density of each color
<Apply>
/b_key_home18.gif)
If the issue persists, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
02-04-2019 12:53 PM
Hi rbaroncpd.
<Menu>
<Function Settings>
<Printer>
<Printer Settings>
<Print Quality>
<Density>
<Apply>
/b_key_home18.gif)
