MF 4890dw Not scanning
jamball
Win 7x64
I have downloaded the latest drivers from the Canon website. I've tried both scanning over the network (no problems with printing) and over USB (again, no problems), but for the life of me, I can't get the darn thing to scan.
I keep getting the scan MF error 162, 0, 0 or 255, 0, 0 after I did a clean reinstall of the drivers and everything. I KNOW I'm plugged in but when I try using the Canon software I get the 162 error code and a data transfer error code.
Please help.
7 REPLIES 7
Patrice
Whiz
Hi Jamball.
The error codes 162,0,0, or 255,0,0, usually indicate that you have not selected a scan type at the machine.  Please follow the steps below to perform a scan from the imageCLASS MF4890dw:
  1. Verify that MF Toolbox is closed on the computer and press the [SCAN] button on the printer.
  2. Highlight [Remote Scanner] and press [OK].  The screen will show, "Remote Scanner. Waiting online...".
  3. On the computer, open the MF Toolbox and select [PDF].
  4. Click the green [START] button on the [PDF] window.  The machine will start processing the scan.
If you receive any errors or need further assistance with the MF4890dw, we recommend that you contact us at 1-800-OK-CANON (1-800-652-2666).
I have scanner MF5980dw  and comuter with windows 8.1
I download latest driver from canon web site
I install toolbox 4.9
I have wifi connection
on scanner menu I select scan mode and remote scanner
but during scanning programm notice that
Error in Scanner
Follow instruction in the on line manual
Scanner driver will be termonated
Error 255.0.0
please send me rely ASAP
Taras Pikhota
Kiev Ukraine
e-mail: taras33@ukr.net
Best solution, but first on my taskbar i created a shortcut of the toolbox 4.9 from all programs/Canon/ right click on toolbox and pin to taskbar, there a countdown when you click SCAN on the printer, so i click the SCAN button on my PRINTER MF4700, choose option REMOTE SCANNER jump on my computer and click the shortcut on my taskbar and i choosed personal 1, i set this one to JPEG and 600 DPI, the printer will configure the TOOLBOX and the scanner togheter, and everytime you need to scan a picture or a document, choose any of the 8 icones et voila !
I have a MF634CDW that had the same problem.  I am running Windows 10 and it is connected wirelessly.  I was able to resolve it by:
1) ON PC, start Canon MF Scan utility, select settings, select General Setting tab
2) select your canon printer button
3) in dialog box, deselect and select your canon with mac id listed, then click OK
4) click OK button to exit General settings
5) ON PRINTER SCREEN; press scan button, select computer, your printer should in dropdown, select it, OK!
6) now try rescanning from MF utility on PC.  It worked for me.
If printer does not show up in step 5, try rebooting modem/router and retrying it again from step 1.
Good Luck!
johnmac
Log into the printer using Remote UI. Then, goto into "System Settings", and turn off (remove the check mark) under "USB Device Settings: Use USB Device". Click on OK to save the settings and then turn off printer and turn it back on.
I have MF 5980dw  and I cannot to solve problem with error code 255 0 0
Can you explain more detailed how get Log into the printer Remote UI - what does mena remote UI?
I wait for your kind reply!
regards
johnmac
Connect your computer to your home network or use an Ethernet network cable from your computer to the printer. Refer to your users guide on how to do this. Afterwards, go into the printer's user interface, your printer can be set Tina specific IP address it your computer router might give it a random address, like 182.168.9.100 for example.
Enter for a chance to win!
April 20th-28th
