02-07-2018 04:46 AM
Good day,
I added new paper to my printer, and an error message appears everytime I print a document, prompting me to select the correct paper source. I have disabled the manual feed source and still everytime I want to print a document, I have to select the paper tray before it starts to print.
I have attached an image of the message.
Please help?
02-07-2018 08:43 AM
Hi, LouisGroen!
Welcome to The Canon Forums, and thanks for posting!
We appreciate your participation, though we need to let you know that your product appears to be a model that is not supported by our team here at Canon USA. The Canon Community Forum is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please click HERE and select your country to find support in your part of the world.
Feel free to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
Thanks for choosing Canon!
03-20-2019 01:46 AM
Your com's print setting for paper size must be letter size.
Your printer's ltr paper size is A4.
So, you have to change the print setting paper size of com. to A4.
09-18-2019 09:51 AM
I am having the same issue -- I most certainly have a printer bought and sourced in the US -- an Imageclass MF741cdw. It is displaying the same exact thing everytime I print as what appears in this poster's image. Since my printer was purchased in the US, can you please simply tell me what the fix is so I don't have to manually get up and go to the other room to select an option everytime I print something? I basically can't queue up multiple print jobs and have to go downstairs for every single thing I need to print.
01-22-2020 07:49 PM
You have to install the canon driver. The windows 10 driver causes that error. Found it through trial and error. Delete the device and install using the software that came with the printer.
03-19-2020 02:31 AM
04-21-2020 05:00 PM
Thanks. Your solution worked for my MF743 model. You were much more helpful than Danny the Canon Moderator.
07-24-2020 12:43 AM - edited 07-24-2020 12:45 AM
Thank you Mailinator! Your response fixed my Load paper.LTR/Plain 1 printing error on my MF743Cdw
07-31-2020 01:32 PM
Would you be able to walk me through that for the MF743? I went to pronter settings and made tray 1 LTR. Then I went to Windoes/settings/devices/printer/print preferences/ and set LTR and Tray 1. I still get the error the first time I try to print. Thanks again for your help!!!
07-31-2020 01:51 PM
It didn't work for me either hence my earlier post. I had to unstall the old print driver that windows installed and use the canon software to install the driver. That fixed it for me.
