02-07-2018 04:46 AM
Good day,
I added new paper to my printer, and an error message appears everytime I print a document, prompting me to select the correct paper source. I have disabled the manual feed source and still everytime I want to print a document, I have to select the paper tray before it starts to print.
I have attached an image of the message.
Please help?
08-01-2020 12:08 PM
Yep, you're right! Loaded the Canon driver and everything seems ok now. Thanks!
02-21-2021 03:40 PM
Great resolutoin!!! Thank you.
My brand new Canon ImageCLASS MF743cdw had the exact same problem.
It refused to print from the tray and would flash an error on every print job!
Load paper.LTR Plain 1
I applied the fix you recommended and now every print job is a breeze. No more manual intervention
Thank you
08-12-2021 04:33 PM
Thank you Mailinator! I was losing my mind trying to figure this one out and never would have gotten there on my own. ![]()
09-10-2021 10:12 AM
This is the best answer out of any of the `work arounds` being discussed. For whatever reason the MS packaged Canon driver gives the printer a mal-formed request when it comes to addressing paper size/tray targets. If you simply download the 135mb driver package from Canon USA support site and install it your headache will be gone forever with regards to this issue.
Cheers,
-RF
11-15-2021 05:28 AM
02-01-2022 12:29 PM
Thanks Mailinator, I tried the others, this one worked immediately.
10-17-2022 12:50 PM
Hi, I have the opposite problem, the Printer ask me to Load A4 Letter.
I live in the USA. In the printer setting and selected LTR paper and make sure document is set to LTR.
I am able to print but the margin is correct. I can't print Avery mailing labels since things don't line up
How do I fix this.
thank you
