02-15-2021 03:57 PM
computer says documents won't print; printer has no error message (or any sign of activity)
two weeks ago spent 2 hrs on hold to get it fixed; problem now recurring.
last attempt to fix before i just return the item and get a printer that actually prints
02-28-2021 09:44 PM
02-16-2021 02:04 AM
@dpreston316 wrote:computer says documents won't print; printer has no error message (or any sign of activity)
It sounds like a communication issue, but this is only a guess. We can try to help, but you'll have to give us more infomation.
"Computer says"... PC, MAC... which OS?
Printer is connected to.. What and how? (USB, Ethernet, Wireless)
"Issue was resolved 2 weeks ago"... What was done, how was the issue resolved?
All we know is you had a problem, it got resolved, and now it has returned.
02-16-2021 08:05 AM
computer: PC
wireless connection
last fix involved reinstalling drivers, and ultimately the Printer had switched its IP address.
02-16-2021 09:38 AM - edited 02-16-2021 09:47 AM
This is what I suspected.
Assign the printer a static IP address. This is done on your router.
Remove the printer from your system, you do not need to uninstall its software. Now re-add the printer using its IP address.
See my reply in this thread.. different model printer, but 100% applicable to your situation:
Re: CAnon Pixma MX922 connecting wirelessly - Canon Community
Just to be clear, the behavior your are experiencing is related to your network, not your printer. Any wireless device using DHCP can eventually have this problem unless you use a persistent destination, or one that doesn't change. Its easy to fix, and only needs to be done once.
02-16-2021 10:09 AM
thank you - the linked explainer is very thorought - one question, how do i assign a static IP on the router?
02-17-2021 10:00 AM
This depends on the router model. Provide that and I will attempt to find an article or instructions for you.
02-20-2021 12:07 PM
router is technicolor tc8715d
how do i find the IP address using the printer menu?
02-26-2021 10:13 AM
See page 63 of the routers manual:
technicolor-tc8715d-userguide.pdf (d15yx0mnc9teae.cloudfront.net)
02-28-2021 09:44 PM
Great, thank you so much.
