07-19-2020 01:43 AM
We have a Canon ImageCLASS 8580cdw on Surface GO mini-portable device. The printer will install but the installation fails at the scanner portion. Any ideas?
07-20-2020 04:17 PM
Hi there, WCEPLLC.
The MF8580Cdw is comaptible with the latest version of Windows. If you're installing it from the CD, try instead downloading and installing the drivers from the MF8580Cdw Drivers & Downloads page. If installing for use by USB, ensure the Surface GO is plugged in and charging.
07-20-2020 05:59 PM
I have tried installing from the download of drivers for a printer on the network. The installation fails when it tries to install the scanner drivers.
07-23-2020 02:25 PM
Hi WCEPLLC.
If only the scanner driver is not installing, then there may be a conflicting program or other issue on the computer. If you're located in the U.S., our support is available at 1-800-OK-CANON (1-800-652-2666) Monday-Friday from 10:00 am to 6:30 pm ET, excluding holidays. If you're located outside of the U.S., you may find your local branch of Canon at https://global.canon.com/en/support
In the case that the issue cannot be corrected by our support, you will need to contact support for the computer.
