12-08-2019 09:08 PM
I've tried multiple different .pdf files and the printer will not print more than 6 double sided pages. I've downloaded and installed the latest drivers on two different Macs, one running High Sierra and the other running Catalina. I've gone into the settings menu on both computers and removed all the printers and reselected the printers after the dirver update and rebooted the machines. I've connected the USB cable individually to each computer to print directly. I've reset the MFP settings using the MFP menu. Images in the .pdf file are hit & miss printing. Some are scrambled others show up as all black. No print error messages on either Mac, the print buffer clears and there are no pending jobs. At my wits end with the thing.
12-13-2019 08:49 PM
Still no luck, I erased my Mac drive, re-installed OSX. I deleted the printer and fax from the settings. Re-Installed the Canon drivers 11/26/19. Added the printer again. I get 4-6 double sided pages and thats it. The print dialog says Printing-Sending data to printer but above that it says: The printer is not connected. After a short period the que clears as if it printed. It's for certain the printer, I'm getting no errors on the Mac. I printed out the 5 page printer configuration report but I dont see anything in the settings that looks out of place.
12-16-2019 12:41 PM
Hi CS223.
Is the D1150 connected over a network (Wired LAN), or by direct USB connection? If by USB, are you connecting through a USB Hub, or directly to the computer?
Is the computer a laptop or a desktop? If it's a laptop, is it running on battery power?
From which programs are you printing the PDF? Have you tried printing them from other programs?
Is a firewall installed on the Mac?
I look forward to your responses.
12-16-2019 01:45 PM
12-18-2019 01:18 PM
Hello again, CS223.
Try using a different USB cord; while they tend to last a while, USB cords may wear out over time. Also ensure the USB cord is no longer than 10 ft, and not coiled or bunched up. Coiling or bunching can damage the cord and reduce the signal strength through it.
When adding the printer back to the computer, what drivers are being selected in the "Add New Printer" screen's "Use" drop down? If it's defaulting to Airprint or Bonjour, manually change it to the Canon option (it will be listed in the Use drop-down options). Video steps
12-21-2019 03:33 PM
03-18-2020 05:04 PM
Hi CS223.
The printer itself won't ignore print commands from the computer, especially over USB, unless otherwise set to limit printing. Check that the Administrative settings on the printer allow more than six pages from your computer or Department ID.
If the above doesn't correct the problem, check your computer's security settings and, if installed, security software to ensure the data over USB isn't being blocked, metered, or limited. For help with settings in Mac OS, refer to Apple support (non-Canon link: https://support.apple.com)
10-10-2020 05:24 PM
Darius,
My printer has had a similar problem. I print over a USB cable from a MacBookPro. It only prints the first few pages of a job.
After
Press < or > to select <MANAGE DEPT. ID>, then press [OK].
I can turn this option on or off, but I am not offered the Page Limit Set menu item:
Press < or > to select <PAGE LIMIT SET.>, then press [OK].
What am I missing?
Thanks,
Joe
10-19-2020 01:48 PM
Hi Banjo,
Try these instructions after reaching Manage Dept ID:
1. Press < or > to select <REGISTER DEPT. ID.>, then press [OK].
2. Press < or > to select <PAGE LIMIT SET.>, then press [OK].
•You can select <TOTAL PRINT LIMIT>, <COPY LIMIT>, <BLACK SCAN LIMIT>, <COLOR SCAN LIMIT>, or <PRINT LIMIT>.
3. Press < or > to select < PRINT LIMIT>, then press [OK].
4. Press < or > to select the desired function, then press [OK].
•The <TOTAL PRINT LIMIT> screen is used as an example.
5. Press < or > to select <OFF>, then press [OK]. This will clear the page limit for the setting selected.
6. Press [Stop/Reset] to return to the standby mode.
If you continue to have difficulties, please contact our support group using the following link:
10-08-2022 10:43 PM
I have a similar problem printing from my Mac Pro. Seems number of pages printed is random sometimes 6 other times 15 etc. I have tried everything. Going to return printer. Not worth my time trying to fix. My other canon printer works great; this one is not worth the effort.
