04-30-2018 10:33 AM - edited 04-30-2018 10:33 AM
Good morning all --
I'm attempting to program a print job -- I have a multiple-page PDF document, and I want to insert sheets from 5 different paper trays. But when I go into program the job, I se the first insert from Tray 1 -- when I set the second insert to draw from Tray 2, the first insert setting reverts to pull from Tray 2 as well. What is causing this? I am assuming it is possible to print inserts from multiple trays (which I have done before, I'm pretty sure). TIA for any help or guidance.
04-30-2018 10:44 AM
Thank you for posting! While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
Thank you!
