03-05-2022 10:53 PM
My printer model Mf642cdw
Is having to be restarted every time that It won’t load the printer’s Remote UI IP Address and at the same time when that happens- I also can’t print to it from my phone, I couldn’t find it on an Android and iPhone in the AirPrint list of found printers and with the Android even if I install the Canon print plug-in
03-17-2022 02:43 PM
Hello Johnlabib195,
If you are unable to access the remote UI and then are unable to print from any devices on the network, it will point to a drop in network communication. In this situation, you can try unplugging your router from the power for 5 seconds. Once the network is back up, you can check if you can print and access the remote UI. You can also try moving the printer so it has a better connection to your wireless router.
