ImageClass D1620 the scanner feeder doesn't work
ShW
Dear All,
I have ImageClass D1620 bought half year ago, recently trying to scan by feeder. Everytime, when I power up the computer, I have to re-install the driver if using the feeder feature, or it'll show the error message as below.  The greyglass scan feature is fine.  However, with a bunch of paper to scan, the greyglass one-by -one scan is impossible task. Does any one know about this issue.
"Cannot  communicate with the scanner.  The cable may be disconnected, or the scanner may be turned off. Check the scanner status and try again. The scanner driver will be terminated.
Code: 155,0,0 "
After the error message, re-install the driver will fix the problem, but if turn off the computer, next morning, power up, the same error message pops up.
Does any one can help?  I tried to call support, but their phone system is like a labyrinth.
Thanks
Jolin
4 REPLIES 4
Audrey
Enthusiast
Hi Jolin,
Thank you for your inquiry, and welcome to the Canon Forums. We appreciate your participation, however, for the community to best assist you can you provide us with the following information:
1. Operating System of the computer?
2. How is your printer connected?
3 .What files did you downland and install?
4. Are you scanning with MF Scan Utility?
If this is a time-sensitive matter, our US-based technical support team is standing by at 1-800-828-4040 weekdays between 10 AM and 6:30 PM ET.
Hi Thank you for your support! To answer your question:
1. Windows 10 Pro 64 bit
2. by USB cable (the third jack on the back panel of the printer)
3. Install from the CD driver come with the printer
4. yes , MS scan utility
The greyglass one-by-one is working, but not the feeder, unless delete the driver from the computer and re-install the CD driver every time once turning off the computer and powering up.
The printer serial number 2SN[xxxxx] , bought from Amazon on August 2020.
[Serial number edited to protect privacy.]
Hector
Hello ShW.
If you are having to reinstall after restarting. I would suggest unsintalling the current driver and MF utility. Once the utility and the drivers have been uninstalled. You can download the latest version of the drivers and software for WIndows 10 using the link HERE.
You will want to download the [Windows 64bit] D1650/D1620 MFDrivers that is under recommend Drivers. For steps on how to uninstall the the drivers and the MFUtility, you can use the link provided HERE.
Did this resolve your issue? If so, please select accept as solution so others can find the answer.
Dear Expert, I followed your link to uninstall and reinstall. It works when the computer is started the next day, but it does not work on the third day. This is the same problem as before.
Should it be sent to you for repair?
Holiday
