Image Class MF8280Cw printing 1/4" thick black lines
Terry5
Image Class MF8280Cw has started printing 1/4" thick black lines horizontally across the page.  It seems to be a random number of lines with smudge lines in between.  Machine is also getting noisy and spends a long time cleaning itself after the first page.  Have no idea what to do.
1 REPLY 1
Audrey
Enthusiast
Welcome to The Canon Forums!
Please try fixing unit and transfer belt.
Fixing Unit Instructions:
1.  Press home button.
2.  Use / to select <Adjustment/Maintenance>, and press OK.
3.  Select <Clean Fixing Unit>, and press OK.
4.  Press OK.
Cleaning starts. When the <Finished.> message is displayed approximately 1 minute later, press  to return to the main screen.
Transfer Belt Instructions:
3.  Select <Clean ITB>, and press OK.
4.  Press OK.
Cleaning starts. When the <Finished.> message is displayed approximately 1 to 2 minutes later, press  to return to the main screen.
Please retry reseating the toner cartirdges. If the issue continues, please try replacing with geniune toner cartridges.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
