09-27-2016 02:57 PM
I have a MF4890DW all-in-one laser printer. When I need to scan a document, I use "remote scanning" and initiate the scan from my Mac using the "MF Toolbox" software. The scanned copies always come out dull - many times not capturing anything writtem with a blue or even black ink pen (for example my signature in a document). How do I change the scan settings to increase the density of the output? I use the black/white or grey scale mode for scan and not the color mode. The main reason is that the color mode generates a much bigger file than black/white.
Thanks.
11-01-2016 04:22 PM
Hi varadacr.
I will be glad to assist you.
To adjust the brightness of the scan, you will need to access the ScanGear MF driver. Please follow the instructions below:
To access this driver, please follow the steps below:
1. Verify that MF Toolbox is closed on the computer and press the [SCAN] button on the printer.
2. Highlight [Remote Scanner] and press [OK]. The screen will show, "Remote Scanner. Waiting online...".
3. On the computer, open the MF Toolbox and select [PDF].
4. In the [PDF] window, click the check box for "Display the Scanner Driver"
5. Click [Apply] at the bottom of the window.
6. Click the green [START] button on the [PDF] window. The ScanGear MF driver will open.
7. Click the [Advanced Mode] tab.
Once [Advanced Mode] is open, you can adjust the brightness and contrast of a document by clicking on the [Brightness/Contrast] icon. The icon resembles a half-white, half-black sun. You may need to adjust these settings a few times to get the image quality that you prefer.
I hope this information is helpful to you. Should you need further assistance, please call us at 1-800-OK-CANON (1-800-652-2666).
