05-12-2013 11:29 PM
Just bought Canon MX922 printer and having some trouble at setup with MP-101 paper fitting into cassette. Seems too wide to fit in. Am I having spatial orientation issues or is this something others have noted? Thanks
05-14-2013 09:40 PM
Hi gthag,
The cassette is designed specifically for plain paper. When using Matte or Glossy photo paper, please use the rear tray for pritning.
06-13-2013 10:19 AM
The set up instructions specify to load the MP-101 paper into the lower cassette. Neither the MP-101 paper nor plain paper seem to fit between the right/left paper guides in this cassette. ??
06-13-2013 10:36 AM
I just did the same thing - The "lower" cassette has two parts - see if you can pull another drawer out below the one you tried - the paper does fit in there... the upper one will just fit envelopes it seems. Stealthy lower drawer!
12-04-2013 03:46 AM
Ok. It's nice to know tha lots of other people have this problem loading plain paper. But WHY?
01-17-2014 05:55 PM
01-24-2014 12:49 AM
06-02-2014 02:49 PM - edited 06-02-2014 10:28 PM
There are two 'lower' trays. For a first time user setting up the printer it easy to pull out the top lower tray which
is for printing CD's.
Lift the printer slightly from the side to pull out the very bottom tray and the mp101 paper for print head alignment will fit.
07-22-2014 04:23 PM
Thank you! You saved me!!!
12-28-2015 11:05 AM
I've found the lower tray , but the test page keeps coming back with error code 1008
