E-mail mesage sending
zoltan
I have in the workplace one canon C2020L colour multifuntional copier , I need some help to configuring him to send  e-mail direct from scaner , first I dont know is the mashine is capable to do that?
In my workplace I already using 3 canon ir2530i to sending emails from scanner.
I find the settings for network but not where is the setup for email addres
2 REPLIES 2
DavidTomblin
I have found on the IR 1730 if that the email address setting is under the ifax settings, also check out the smtp settings under network/tcp/ip settings for ports and smtp server address, which is also necesary
David Tomblin
Moderator
Moderator
Hi, zoltan!
Thanks for posting! While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
