Drum toner Spot
srob7529
Hello
I haev a CANON Image class MF731cdw and i have yellow toner spots on the rihght side of the paper eveytime i print in color. How do i fix that. Please help
1 REPLY 1
Start with the obvious.  Remove the "Y" toner cartridge, inspect it and the carrier for problems.  You can use canned air or vacuum to clean things up if needed.  Try replacing the cartridge, does the problem follow?  Now you have ruled out the cartridge itself or issue with the printer.
