10-19-2014 12:47 AM
10-21-2014 02:02 AM
Hi everyone
I finally got this solved! Spoke to Canon representative here and I was advised to use the driver which is meant for 10.9 and that it would work.
So I googled for it, found it at this address: http://iprinterdrivers.com/download-driver-canon-ir-adv-c2220-printer.html
And installed it (successfully!), added my printer from the network (I chose HP JetDirect insteal of IPP as I had problem connecting when using IPP, found the solution here: https://discussions.apple.com/thread/6573512) and it now works like a charm! Yay!
10-20-2014 09:03 AM
I'm also having this problem. I get the message 'filter failed.'
10-20-2014 09:08 AM
Hi! Thanks for posting!
While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer, please call our US support center at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area!
We hope this helps!
10-20-2014 09:28 AM
Hi Danny
Thanks so much for the info! Btw, do you happen to know any dealers in Malaysia?
I tried installing it using the version that works with Mavericks but an error occured telling that it does not support my current OS (Yosemite)
Thanks
10-20-2014 09:35 AM
Hi, edahani!
As this forum is hosted and administered by Canon USA, we can only provide direct support for our US customers. We recommend visiting Canon's global site and selecting your part of the world from there.
We hope this helps!
10-20-2014 10:57 AM
Thanks Danny! Contacted Canon Malaysia for more details.
10-21-2014 02:02 AM
Hi everyone
10-27-2014 02:03 PM
Hi, I found this link http://printer.8driver.com/download-canon-ir-adv-c2220-printers-driver-and-install.html , It work for me! Good luck
