06-01-2022 12:00 PM
Hello all,
First I want to say thank you for taking the time to read this message, it means a lot to me.
My question was for my Canon Maxify Mb2320. A week ago it was working fine, now when I start it, it will not stop power cycling. Once you press 'On' it does indeed come on, after pressing the 'On' it will shuffle one paper, do some stuff and then turn off and rinse and repeat. It will continue to do this as long as it plugged in, even for 30 minutes... etc.
I was also curious if a hard reset might help, how might I do that?
Thank you
Sonam Tashi
06-04-2022 04:19 PM
Hi! We've released a firmware update to take care of this issue. Learn more now by clicking HERE.
Hope this helps!
06-01-2022 12:08 PM
you are not alone in this situation. There are several other posts regarding the constant power cycling.
06-01-2022 12:09 PM
Here is the fix everyone! Thanks italolima
Canon DNS error, need fixed ASAP.
MX490 power cycling fix from user on forum SPREAD THE WORD!
My printer is a Canon Maxify MB2010. This problem that you are experiencing is because of DNS.
https://community.usa.canon.com/t5/Desktop-Inkjet-Printers/MX490-power-cycling-fix-from-user-on-foru...
jperez739, Apprentice 05-31-2022 09:11 PM
06-01-2022 12:12 PM
its a work around, not a fix.
06-02-2022 11:08 AM
My Maxify MB5020 has also started to cycle continuously. It is an older model, but was working great. I cannot get the main screen because the printer continuously cycles. So frustrating,......of course Canon discontinued, so there is no support available. Hopefully they have a patch soon.....ugh!
06-04-2022 04:14 AM
Canon Maxify MB2320
Printer started power cycling when Canon screwed everyone else this past weekend. I took the DNS "Fix" and instead of doing all of the steps I only....
Printer bought in 02.2015 and have never installed a firmware update and whatever Canon did this weekend, it still affected mine
06-04-2022 04:19 PM
Hope this helps!
06-06-2022 09:17 AM
What about the MB5050? I dont see a fix for this one...
06-06-2022 09:32 AM
We are only able to provide support for Canon products manufactured for and used within the US market. The MAXIFY MB5050 is not supported through Canon USA. Please click HERE and select your region for support.
