04-20-2023 11:22 AM
Looking to buy the
Canon imageCLASS MF642Cdw Wireless Color All-In-One Laser Printer
unfortuallty i cant see which additional paper tray can be installed. It doesnt state the model # in the manual... so i need professional help.
i got the
Canon Lasers AF-1 Optional Paper Cassette Printer Feeder, White sitting here and i wonder if i can install that on the
MF642Cdw
Thank you
Florian Silbereis
04-20-2023 04:05 PM
As best as I can tell, this model doesn't support additional paper trays. If you look at the MF642cdw specs, it states:
PAPER CAPACITY (LETTER, 20 LB. BOND):
250 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND):
250-sheet Paper Cassette, 1-sheet Stack Bypass
Contrast this with the LBP236dw specs:
Standard: 350 Sheets
Maximum: 900 Sheets
Standard: 250-sheet Paper Cassette, 100-sheet Multipurpose Tray
Optional: 550-sheet Paper Cassette (Cassette Unit-AH1)
The lack of an "Optional" entry for paper sources, and no differentiation of standard/maximum in capacity suggests that the MF642cdw does not have expandable paper capacity.
04-20-2023 04:05 PM
250 Sheets
Maximum: 900 Sheets
04-20-2023 04:08 PM
ha! I see... , ok, well good to know then. 😞
