Canon Maxify MB2720 - Ink Levels with a Question Mark?
trproperty
I can't change the cartridges because there isn't a way to move them to the front without the machine actually knowing they're empty, right? So...now my machine is stuck and I can't really print anything on it. How do I fix this? Is anyone else in this spot?
xmen
In the meantime I found a solution to the problem.
Check this video on how to remove the inkt-tanks : https://www.youtube.com/watch?v=QVLrSWHgkM8
removing all the inkt tanks. Powering on the machine and reinstalling them with the wizzard, solved my problem.
4 REPLIES 4
Hector
Hello Trproperty,
If the ink tank has a question mark on it, it will mean the tank is malfunctioning and the printer can't detect the current ink level. The Maxify printer will not move the ink to the changing position unless the printer detects that the ink is empty.
In this situation, you can try deep cleaning the black ink until the ink starts to flow again or the level for the black ink reads as empty. If you are using a third party ink tank, the tank could be the issue and you can check with the company that made the tank to see how to manually remove it.
I have the same problem here ...
Deep cleaning the nozzle's did not help.
I'm stuck with an unusable printer.
Hector did you re-read what you actually wrote ?  " check with the company that made the tank to see how to manually remove it" -> it is not the tank keeping itself in the printer. It is the printer offering no possibility to release the ink tank.
xmen
Nice work around. 👍 Turn the gear to release and eject one by one.
