Canon Maxify MB2720 Error Code 5207
deseomar
Hello,
I have a Canon Maxify MB 2720 that will not print due to error code 5207. The Printer is OUT of warranty.
I have changed all the ink cartridges. I have powered it on and off several times.
I have tried to pull the plug and press on button 10 times. The error code still comes up with no additional information.
Also, these things are properly verified:
- I updated my drivers and software
- The printer was working fine a few weeks ago
- There is not a paper jam
- The ink trolley moves fine and all of the ink levels are above minimum
- There is correct paper in each try (letter in both)
Are there any other suggestions that I might get this thing to function properly?
9 REPLIES 9
jp07
Same problem.
Hector
Hello,
The 5207 error would point to a problem with the hardware. The issue would point to a problem with the carriage that the inks load into or the nozzle that the ink sprays out of. If replacing the ink did not resolve the issue, it looks like the printer needs service or replacement parts.
Outside of the 1-year warranty, you can contact our sales team at 1-800-385-2155 and use our Upgrade program. The program would give you a discount and free shipping on a replacement printer. We do not have service centers that work on this model, but you can check for any third-party office equipment/printer repair in your area.
I have since moved on to another brand of printer and will never buy a Canon printer again.
Canonproblems7
The 2720 I bought in April 2025 has been a problem for 6 months and then it just shuts down and despite putting in new yellow  ink refuses to operate ( B504) and I cannot find any responses to such issues and it seems to just be junk .
Me again ...Despite the "instructions " and two days of The "B504  " problem ... I just decided since it was junk to do things I was not supposed to and using my hand I moved the ink cartridge to the slot and the white plastic circle until it clicked ( clock wise ) and took out the new ink and wiped the messy end of yellow goo and put it back in and turned it on ...and ,,believe it or not it is printing fine now !!! So apparently it just decided the new ink was bad until I improperly removed it and reinstalled it and it decided it was fine then !!! I will not have to replace it now ! I wish I was not retired and still had a Secretary !!!!
I have exact same problem.  I performed all the steps then proceeded to try to clean the rollers.  At this point, the error popped up again and would not perform the task.  What are my options here?   Thanks for your help.
I am considering the same.  I called support numerous times and each time I was told to add money to my account.  No thank you.  I will not add money to my account just to talk to someone to tell me it's a dead printer and I need a new one.
The 5207 error code on a Canon Maxify MB2720 printer indicates an issue with the print head. Here are some steps you can take to try and resolve the problem:
  1. Initial Checks:
    • Ensure the printer is powered on and connected properly.
    • Check that all ink cartridges are properly installed and have sufficient ink.
  2. Print Head Cleaning:
    • Access the printer's menu on the control panel.
    • Navigate to the 'Maintenance' or 'Setup' section.
    • Select 'Print Head Cleaning.'
    • Follow the on-screen prompts to start the cleaning process.
    • After cleaning, print a test page to see if the error persists.
  3. Deep Cleaning:
    • If the standard cleaning doesn't work, try the 'Deep Cleaning' option (if available).
    • Note that deep cleaning consumes more ink.
  4. Print Head Alignment:
    • In the 'Maintenance' menu, look for 'Print Head Alignment.'
    • Follow the prompts to align the print head, which can sometimes resolve print quality issues that trigger errors.
  5. Contact Canon Support:
    • If the error continues after these steps, contact Canon support for further assistance.
    • You can reach them at canon.us/account or call 800-OK-CANON (800-652-2666).
Thank you, Stephen.  I have tried all those steps previously.  All ink cartridges are installed and plenty of ink. It would not print because it could not pull the paper.   During the print roller test, it stalls out.  What does that indicate.
