Canon MF743Cdw will not print gradient fill
GHCCDS2025
My Canon MF743 Cdw will not print gradient fill boxes.  I've tried pages (mac) and PDF.  I can print the gradient fill on my B&W Brother printer so it's not the software. The toner is full and was recently replaced. The firmware is up-to-date.  I've gone through the gradient fill calibration process on the printer.  It also did not fix the problem.  Everything else, including color photos, will print. It's only the gradient fill boxes that will not print.  Any suggestions?
Thanks in advance.
2 REPLIES 2
DerrickL
Whiz
Whiz
I suspect you have seen this guide before, but just in case you have not:
https://oip.manual.canon/USRMA-3547-zz-SSM-740-enUS/contents/devu-mainte-ajst_imaqua-gradation.html
GHCCDS2025
Yes.  I have.  It did not work.  Thanks for the response.
