06-17-2020 01:57 PM
I've owned my Canon MF743Cdw for a couple of months now and wanted to see if there is any way to create a shortcut with specific options for Scan to File? For Copy, I can hit the favorite shortcut button and off we go.
For Scanning Double Sided:
Homescreen
Scan
File
Address book
Send Settings
2 sided On
Color/ BW
Would love to have setup 2 shortcuts to do all this with one button if possible, one for regular scans & one for double sided. Worst case, is there a way to clear out the scan recall settings or rename them so I can mark one double sided?
Any suggestions?
06-17-2020 04:14 PM
Hi Dawnye.
Some customization of the main screen options is available using the Application Library and the Remote UI.
I'm unsure of whether the available options will get you the full breadth of presets about which you're inquiring, though it should get you closer to what you desire.
06-17-2020 04:14 PM
Hi Dawnye.
