03-05-2021 05:40 PM
Hello,
My CANON MF743CDW will print one job. I then pick new jobs to print and nothing will happen until I re-install the driver. Once I re-install the driver it prints again until I load a new job.
I am using MS Windows 10.
Thank you.
03-05-2021 10:16 PM
Greeetings,
This is very obscure behavior.
How is the printer connected, and to what?
What application are you printing from?
Does the behavior happen when printing from all applicaions, or just one, etc?
03-06-2021 07:34 AM
Hello,
The printer is connected on my home network. I connected everything to include my iphone, android, and computer (Windows 10) to the printer. This behavior seems to be the same from all applications.
Also, not sure if this is a coincidence, but seems like after the android failed to print, this issue surfaced. I also installed all of the updates on my Windows recently, maybe that is also what caused the issue? Idk.
Please help.
04-27-2021 06:39 PM
Hello Aslonopas,
If the computer and the printer stop responding after one print and you need to reinstall to continue printing, It looks like there is something blocking the print job on the computer or there is a problem with the spooler service.
If you can reconnect and send a print, the printer's network connection should be fine, otherwise a reinstall would be unable to reconnect and send another job. Instead of trying a reinstall, you can try restarting the spooler service on the computer to see if you can print again.
Once the spooler has been restarted, you can try another print to see if the printer starts to respond.
If the jobs does not respond or if it just prints one more page and the issue comes back, you can try turning off any of the security software on the computer to see if you are able to print without any problems.
If you continue to have issues, I would suggest contacting our support team for assistance at 1-800-652-2666. Our agents would be happy to look further into it for you to see what might be causing the issue.
