07-13-2020 09:50 AM
Since the latest Windows update last week I cannot print on any laptop or computer that has updated windows.
I get the following error message
Operation could not be completed (error 0x000003e3)
The i/o operation has been aborted because of either a thread exit or an application request
the printer worked fine until the windows update
07-13-2020 10:08 AM - edited 07-13-2020 10:09 AM
both 1909 and 2004 can introduce printing issues in some environments. MS has already patched them assuming this is actually your issue.
You can uninstall updates (indefinitely) and or "Feature Install" for up to 10 days. Settings > Update and Security > Recovery.
Might be worth going back to your previous build to confirm that the update is in fact the cause of your issue.
Or
Check to see if you have this update and/or if applying it helps to resolve.
Again, I'm just going off your diagnosis. If might be unrelated.
https://support.microsoft.com/en-us/help/4567523/windows-10-update-kb4567523
07-13-2020 10:44 AM
Thanks. I am assuming I download this version of the KB4567523 update since i am running windows 10 home 64 bit?
2020-06 Cumulative Update for Windows 10 Version 2004 for x64-based Systems (KB4567523)
07-13-2020 11:43 PM
That is correct.
07-14-2020 08:38 AM
Thanks for the help. I contacted support and they had me delete the printer, verify it was not listed in the Apps and Features (if it was, I needed to delete it). The printer utility is ok.
I downloaded the recommended driver on the Canon site and that solved the problem.
I will keep your info as well - just in case! Thanks again!
