Search instead for
Canon ImageClass MF726CDW Prints Vertical Yellow line on the left side of the page
patrocle
Occasional Contributor
I have the Canon ImageClass MF726CDW and it Prints Vertical Yellow line on the left side of the page.
My i had the printer for 2 years and had no problems printing, with same type of toners.
Now for the last few weeks it started to have those vertical yellow line, is not a line, is like 1 inch wide line on the left side of the page...
Here is a picture:
http://i67.tinypic.com/1z3xqv4.jpg
I pulled the toners out from the tray and the yellow toner is the last one, and i am seeing some yellow mark on the big belt or whatever is called that i guess paper goes on it, i clean some ,but i can not turn it, from the front of the printer, unless a back cover can be taken of and have easy access, and also how to release the belt so i can manually turn it and wipe some .
What you think it maybe?
Thanks for any advice.
7 REPLIES 7
patrocle
No one?....any help, will appreciated!
Sonya1
Hello patrocle,
I understand your Color imageCLASS MF726Cdw prints a vertical yellow line down the left side of pages.  If you have not already done so, to restore your print quality, I suggest you clean the fixing unit and transfer belt using your MF726Cdw's operation panel using these steps:
1. Press  and tap <Menu>.
2. Tap <Adjustment/Maintenance>.
3. Tap <Clean Fixing Assembly>.
4. Read the message that is displayed, and tap <OK>.
5. Tap <Start>.
  • Cleaning starts. When the <Finished.> message is displayed approximately 1 minute later, press  to return to the <Home> Screen.
Follow these steps to clean the Transfer Belt:
3. Tap <Clean ITB>.
4. Tap <Start>.
  • Cleaning starts. When the <Finished.> message is displayed approximately 1 to 2 minutes later, press  to return to the <Home> Screen.
 If you need immediate assistance and you're in the USA, please click http://Canon.us/ContactCF for our US-based support. If you're outside of the US, please click http://Canon.us/4xf7 for support options.
patrocle
Thanks for replying!
I try your guide and looks that did not fix it, it got worse looks like ..., I guess there is something wrong with the transfer belt...that does that.
Both prints where done after your guide.
What next now?
Thank you for your help!
p.
patrocle
Any other suggestion? how maby to fix this?
Thanks,
patrocle
I guess not...
If you've followed the above instructions and require further assistance, you'll want to call for support. Our friendly, US-based team can be reached at 1-800-OK-CANON (1-800-652-2666) Monday-Friday 8:00 am to 8:00 pm ET.
patrocle
Thanks for reply.
I have sent email to support.
Waiting for a reply.
Thanks.
