03-21-2020 05:03 PM - edited 03-21-2020 05:03 PM
I have a new laptop running windows 10 and i get an error message whenever i try to print something. i've downloaded new drivers and stll get the message. i tried to print on my old laptop and it works fine. Any idea what could be wrong? Old laptop was also running windows 10.
Thanks.
08-25-2021 07:20 PM
I have similar problem with printer Canon MF4150 after i reinstalled Windows 10. Initially this printer was connected to the same computer with Win 8, but after i reinstalled the OS i can't print anything, even test page. I can see this printer in the system (Win 10 recognizes it), but that's about it, no printing. Please HELP!
Just for the record, I tried all previously mentioned fixes listed in Canon forums and MS forums.
08-26-2021 10:59 AM
10-29-2021 01:22 PM
Hello Buba,
The link that you are referrring to is for our inkjet printers. The MF4150 is compatible with Windows 10. You can download and install the drivers for the MF4150 using the link provided HERE. If you need assistance with the install or if you would like a more immediate resolution to your issue, feel free to contact support at 1-800-652-2666. Our support team would be happy to help.
02-04-2023 03:47 PM
ShesRacing answer fixed my issue.
I recently bought a new PC and the printer was working fine on my old Windows 10 PC. I tried installing the Canon MF4150 driver multiple times from the Canon website but I could only get the scanner to show up.
I followed the Microsoft link instructions in ShesRacing post to add the Canon UFRII LT printer driver to Windows as it only had the default Microsoft printer drivers in the list.
I then needed to manually install the Canon UFRII LT printer from the Windows Printers and Scanners page since the driver was now in the part of the printer drivers list in the previous step. No need to disconnect USB and reconnect USB though. I just left in plugged in the whole time.
I think the key step is to add the Canon UFRII LT driver to the Windows printer driver list following installation of the Canon driver.
