Cannon image runner c1030iF- won't print 2 sided
vivianneconn
I am using a Cannon Image Runner c1030iF. I am able to print 1 sided fine but when I try to print 2 sided, it jams every time when flipping to the other side. Any idea how to correct this problem? Has anyone else experienced this?
1 REPLY 1
tylercaine89
i would check two things. First just make sure the humidity in the paper is not to high. It can cause the paper to curl and jam when trying to duplex. Try a new ream of paper to fix this. Second thing to check is to pull the fuser assembly out of the machine, which youcan get to by lifting up the scanner assembly, and then the top cover. Check the long orange roller on the output side of the fuser unit, and make sure that the little black tab has not flipped up and causing the orange roller to sit crooked. This will cause issues as well. Hope this helps.
