imageRUNNER ADVANCE DX C3830i only scans 4 times and stops
ElementsGroup
I'm having trouble with our cannon scanner. It's a big office type printer scanner. Not sure what it is. It is scanning 4 separate times then won't scan after that. It just keeps trying. I eventually get a "TX report" saying it was "unable to send"
It does this for everyone.
I don't have an IT department anymore, it's just me (Administration)
EDIT: it says it's an Image runner advance DX C3830i
4 REPLIES 4
SamanthaW
Moderator
Moderator
Hi!
To have a better understanding of your issue, please let everyone know the model of the machine you have, if any errors are received, and any other information that might help the Canon Community help you!
If this is a time-sensitive matter, please check out your other support options here: https://canon.us/account
Thanks!
normadel
Are you trying to scan documents to save, or are you trying to Fax? The messages you are quoting indicate Fax errors. Has the machine been setup for faxing? Is it connected to a phone line? More information is needed here.
Moderator
Moderator
Thanks for joining the conversation, ElementsGroup!
While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
Greetings @ElementsGroup,
No IT Dept.  Consider Danny's recommendation.  Find a dealer (near you) who can help.  From your description, its hard to discern if your problem is related to configuration or a problem with the device.  There is significant value having a dealer.  It keeps everything running at the speed of business and when you do have a problem, you can get the issue addressed quickly minimizing downtime.  No need to struggle, help is available.
