03-27-2020 01:55 PM
Hi all,
I've bought the MF643CDW and i am unable to let the printer scan to email. I've seen all the instruction videos on youtube. I've tried everything, but nothing works.
Problem:
I want to install my GMAIL account on the machine:
- Changed the SMTP port to 587
- I changed the SMTP AUTH settings
- Entered my login user name and password
- TLS Enable but not the validate box.
I receive an #839 error. wich means:
Cause | The user name or password specified in Communication Settings is incorrect. |
Remedy | Check the user name and password set for <SMTP Authentication (SMTP AUTH)> in Communication Settings. (See "Common Communication Settings for E-Mail/I-Fax.") |
I've checked every user name en password 100 times, but it does not work.
Someone with the same issues?
03-27-2020 10:47 PM
The username is your full gmail address "[email protected]"
What are you using for incoming / outgoing mail servers?
Do you have 2 factor auth enabled on your account?
Are you allowing "Less Secure Apps"?
03-28-2020 08:40 AM
Username and emailadresbox: [email protected]
Password: correct and checked
SMTP: smtp.gmail.com
TLS for SMTP: check
SMTP port: changed to 587
2factor auth and less secure apps is disabled.
03-28-2020 01:20 PM
There is a thread covering this topic on the very front page https://community.usa.canon.com/t5/Office-Printers/Canon-MF645x-Gmail-SMTP-settings-please-help/m-p/...
03-29-2020 12:00 PM
Problem solved.
Solution: create a new Gmail account and everything works fine!...
Thanks everyone for your help 🙂
