Can't replace ink - won't center
Gormican
I have a Maxify MB2320.  I bought replacement ink from E-Z Ink on Amazon which said it was compatible with my printer.  I had to turn if off and on each time I wanted to print.  So I was going to remove the off-brand ink cartridges and install Canon cartridges, but when I open the door, the printer head does not move to the replacement area and the screen displays "The front cover is open.  Close the cover".  Is there a way to get the old cartridges out?
3 REPLIES 3
Gormican
Looks like this problem has everyone stumped.  Anyone have a strategy that might work to save the printer?  Otherwise, it looks like its off to the trash.  It's a bummer because it's relatively new.  I wish there was a fix.
Hello.
Additional troubleshooting will have to be done to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
Thanks.  Finally got the answer.  Since the cartridges are under pressure, you can't remove them until they are low.
Avatar
